How do I fix the black screen?
I dropped it on a hard surface with the screen protector on , it powered up ,the volume buttons work and notification sounds are on but the screen remained black. How can I fix it?
Esta é uma boa pergunta?
Sounds like you broke the LCD. If you are sure the Device still turns on then the LCD is likely to be damaged.
You would need to replace the screen there is a guide on how you can replace that phone Samsung Galaxy Alpha Display Assembly Replacement
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 3,253
