Device won't hold a charge, what do I do?
When the charger is plugged into the device the device works fine but when plugged out it dies shortly after.
Esta é uma boa pergunta?
If the device turns on when the charging cord is plugged in, but immediately shuts off when you disconnect the device. Then, I believe that you may have a faulty battery, since the charging port and cable appear to be working properly. I would recommend looking into replacing your battery.
Esta resposta foi útil?
If you need more assistance I would recommend checking out the DKnight MagicBox II Troubleshooting Guide
I'm having the same issue, and at first glance I can't find an easy way to pop the speaker open. Where are the screws hiding?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 2,401
1 comentário
Where I can Buy a Battery for a Big Magic Box???
por djelvis20
