Why won't my screen turn on?
I charged the battery on my camera, but when I press the power button nothing happens. Is my battery damaged?
Esta é uma boa pergunta?
If the battery isn't the problem and you're sure the camera is turning on, check the ribbon cable between the screen and the motherboard and the screen itself. Unfortunately, both of these require opening the case. Be careful, and good luck!
Esta resposta foi útil?
i have the same problem
mine turns on but it has a triangle warning sign and stays stuck like that
i think my wire cut and i repair it but not turning on
so pls tell me how to join the wire together
I'll suggest examining both the battery and flash card door making sure they are in contact. If that doesn't fix it, I'll buy new batteries and see what happens. And if after all these, this problem still exists, then the problem is likely to be internal to the camera.
I just bought this camera put it on the charger and it will not charge?
Light comes on and can be turned on plugged in, but once unplugged it will not tun on...
same thing for me but i used mine once and it dosnt work
I have the same problem used it once and now nothing blue light comes when pluged in but will not power up
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 118
Duração total: 8,630
1 comentário
Put pressure on the battery, I’m putting pressure and the screen now turns on. Maybe put something between the battery cover and the battery.
por raimbow_me
