Never completes startup routine
Startup does a vertical and horizontal pan to the motion limits but stops part way, hesitates and begins again. I don't see how to open the mechanical or camera section of this device. I believe if I can bypass or disable this routine the camera will work.
Esta é uma boa pergunta?
If you pull off the rubber pads, you will see the 4 screws. I opened mine and found nothing obvious to fix.
por SAmmy Mok
