Ir para o conteúdo principal
The Sony Vaio VGN-NW240F is part of the VGN-NW series, which was released in 2009 and comes in various colors. The laptop has a 15.5” (1366x768 resolution) display with an built-in webcam and a compact ten-keyless keyboard.
Diskpart clean wiped all the data?
I just did a diskpart clean during windows install and i accidentally wiped all the drives and when i restarted the pc it said 'operating system not found' seems like i have wiped off the OS as well. Though, i have backed up all my data on a 500 gb external hard drive some time back. Can i install the OS from the external drive (on which i have backed up data)? If yes then what's the procedure to do that?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This is possible if you cloned the drive . If you just backed up your data that does not include the OS then no you cannot. You will need to reinstall a new OS . You must have realized that when you run the diskpart command in the command line it formats the drive tis is to prepare for a fresh windows install. Did you kill the recovery partition as well?
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Saurabh Gulati será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 243
