Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Internal hard drive is not correctly recognized
I thought the hard drive in my MacBook Pro 13" 2010 was failing, because sometimes it would refuse to boot. I bought a new hard drive from iFixit. To my disappointment, it doesn't work either. I was not able to format it after installing it. I put the new drive in the external enclosure and connected it via USB. I was able to format it that way. Then I tried the same thing with the old hard drive. It turns out I can access either drive completely fine when it is connected by USB, but neither drive works when installed internally in the laptop. Disk Utility can see the drive but cannot format it. The error message is "Couldn't unmount disk."
Is it a bad ATA controller or something? Can it be fixed?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Your hard drive cable is bad. Big giveaway is that attempting to format fails but works great on USB. Your part number is 821–0 814–a and it's probably about $20. Unhook your cable and flip it over to see the part number just to be safe
Esta resposta foi útil?
Pontuação 1
1 comentário:
This appears to have worked. Thank you.
por
Adicionar a sua resposta
jvanderhyde será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 53
