Ir para o conteúdo principal
Connecting the home button cable makes the screen turn off?
So, I was fixing a water damaged phone - I attach a screen to test the screen working on the phone (with only the two connectors - not the home button connector) and it works fine.
Then, I install the home button on to the screen and connect the flex cable to the motherboard connector (the one for the homebutton) and the screen doesn't come on.
But then, if I disconnect the home button connector the phone comes on as usual.
Then if I connect the home button connector whilst the screen is on, the screen just turns off?
What could be the problem? It works fine with a different home button, just not THAT home button - but that one's the original one!
Just to clarify which connector I mean - it's the one that the guy is prying off in this photo:
https://www.google.co.uk/search?q=home+b...
Thank you!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have replaced home button and long flex from home button. Still have the phone shutting off when butterfly is attached.
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi John
Today I have the same problem. Water damaged phone when connect the long flex the screen dies.
I just replaced the long flex and left the original home button and it is working.
Hope this help
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thank you so much! I found this very helpful! I'm finding it works with the same long flex, but a different unoriginal home button. Is there anything I can do in this case?
por
No if it doesn't work with the home button you have to change it. Please mark my answer as chosen solution. Thanks
por
I hope you are not unplugging or plugging ribbon cables while the battery is plugged in. It runs the risk of shorting something on accident if you do.
por
Hi, I have the same problem here but the iphone 6 never came in contact with water.
I have already repaired a lot of iPhones but I can't solve this problem. I have send it to apple but they asked $400 to repair it. I have tried to replace the home button and the shield with the home button cable. I can't use the original home button because the ribbon is broken.
Anyone who know to fix my problem?
Pontuação 0
Adicionar a sua resposta
John Taylor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 3,100
