Ir para o conteúdo principal
Lançado na América do Norte em novembro de 2006, o Wii foi o primeiro console de jogo da Nintendo a oferecer suporte direto à conectividade com a internet, permitindo tanto jogos online quanto a distribuição digital de jogos e aplicativos de mídia através do Wii Shop Channel.
How do you fix a button that won't press?
The Wii took a tumble a while back, and since then, the eject button doesn't click anymore. Unless its positioned just right, it'll forever try to eject. How do you fix/replace an eject button?
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
6 respostas
Pergunta mais útil
If I'm hearing you right, the console is constantly trying to eject the disc while the button is not being pressed. A solution you may want to consider is removing the button entirely (I'm pretty sure you can still eject the disc from the Wii menu). Try removing the faceplate to get to the button and remove it, to see if that fixes the problem or at the very least to clean out any broken plastic components that may still be in there. Wii Faceplate
Here's the part: Nintendo Wii Faceplate
EDIT: Whoops! Turns out you can't eject the disc from the Wii Menu. I tried through a whole episode of Seinfeld.
Imagem de Replace the faceplate and its buttons.
Produto
$19.99
Esta resposta foi útil?
Pontuação 5
iFixit now has the part you need to repair your Wii (instructions linked to in BWest's answer)
Produto
$19.99
Pontuação 3
the eject button can be replaced but its very small. I use a digital microscope to clearly see the solder points.
Pontuação 1
clean the buttons some times got dust around
Pontuação 0
Yes and i need you to fix it
Pontuação 0
I took apart the Wii and found the disc holder and pushed the egect button a couple times then put it back together and the your set
Pontuação 0
Adicionar a sua resposta
Kevin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 20,183
