Ir para o conteúdo principal
A 6" random orbital sander/polisher that was manufactured by Bosch in 2003. Repairs may require basic everyday tools.
When do I need to replace the sanding pad?
How can I tell that it is time to replace the sanding pad?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
An easy way to tell if the sanding pad needs replacing is to see if the sanding pad feels smooth. If it does, the sanding pad has lost it's grit and needs replacing.
Esta resposta foi útil?
Pontuação 0
Three things:
- When you start getting swirl marks.
- When it feels like substantially more effort is required to do routine tasks.
- When it stops wanting to stick.
PS...Did you mean Sanding Disc?
Pontuação 0
Adicionar a sua resposta
Roope Virtanen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 519
