Ir para o conteúdo principal
A versão slim do clássico Xbox 360 com disco rígido de 250 GB e Wi-Fi integrado. O reparo requer ferramentas complexas de alavanca e ferramentas especiais.
307 Perguntas Visualizar todos
How can I fix my xbox 360 red dot?
My Xbox 360 slim powers on fix, would play for 10 to 15 minutes then green dot would turn red and d screen would go blank, light on the power supply turns from green to orange. When turned off for 2 to 3 hours, turns back on works for 10 to 15 minutes then red dot appears again. Please can someone help me???
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Red dot, means "fatal failure", The Xbox is indeed a "PC" inside a "box", If you want to fix that you have to open the machine and clean ALL the ventilation holes, after that change the "cooler heat pasta", because Im almost sure is "DRY", after that you can play 24/7. ;)
Regards.
Luis.
Esta resposta foi útil?
Pontuação 0
Thanks a lot, am give it a try an see what happens. One last question, which cooler heat pasta would you recommend arctic silva 5 or arctic cooling mx-4
Pontuação 0
Adicionar a sua resposta
verol fraser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 296
