Ir para o conteúdo principal
The Sony Xperia M2 is mid-range 4G Android smartphone produced by Sony Mobile. Available - May, 2014.
20 Perguntas Visualizar todos
no sim no service any advice
My phone experia m2 keeps coming up no sim no service any advice
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Hi, ik heb hetzelfde probleem. Het schijnt een bekend probleem te zijn bij de experia m2. Je kunt een paar dingen zelf proberen.
1-Haal simcard eruit en plak op de witte kant een 10 tal reepjes plakband, dit zorgt ervoor dat de simcard tegen de contact punten wordt aangedrukt.
2- je kunt een nieuwe simcard pcb kopen en deze zelf er zetten of laten zetten. https://youtu.be/wADy76yTen0
Succes,
Danny
Esta resposta foi útil?
Pontuação 0
Hi , i have the same problem . It seems to be a known problem with the experia m2 . You can try a few things yourself.
1 Remove simcard and stick on the white side 10 strips of tape, this ensures that the simcard at the contact point is pressed .
2- you can buy a new simcard PCB and fix yourself. Make sure you buy for the right type for example D2303, D2305.....
Success,
Danny
Pontuação 0
My phone experia m2 d2302 any sim card insert no service and emergency call only show how to sloved pls tell hardware solutions
Pontuação 0
Adicionar a sua resposta
Michaela será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 3,879
