My camera keeps saying "battery exhausted". How to fix it?
My camera keeps saying "battery exhausted" I've done everything online tells me but it doesn't work. What to do?
Esta é uma boa pergunta?
Hi Cole,
There are a number of possible solutions you can try.
You may have the incorrect battery type selected in your camera's menu. Find out which type of battery is currently in your camera, and check it with your camera's current settings. To view your currently selected battery type (or to change your battery type) press the MENU button > Setup Menu > Battery Type. From here, you can make sure your battery matches the type selected in your camera.
This sounds silly, but you may have to plug in your camera and charging adapter in a specific order. According to Nikon's answers forum, first plug the USB cable into the charging adapter. Then, plug the adapter into a wall outlet, and finally connect the other end of the USB cable to your camera. (Make sure the camera is powered OFF.) Take care to perform these steps in this specific order.
Most likely, you'll need to get a new set of batteries. This particular model defaults to AA alkaline batteries but also accepts AA lithium batteries or Nikon EN-MH2 rechargeable Ni-MH batteries.
If you get stuck, take a look at the Nikon Coolpix L310 user's manual.
Best of luck!
Esta resposta foi útil?
Mine too is indicating there is a charge, on any one of three batteries, i.e. 85% and then after a minute or two indicateds "Battery Exhausted". When I take the battery out and put it back in again, it reads 85% and whole thing starts over. I doubt replacing the battery is the solution. And the other two are (sorry) too nebulous... of course it may be just me but I do have the correct batteries and my camera doesn't charge the batteries I use the charger ( external ) that came with the camera... Sony A77 ii and yes I updated the firmware to the latest version, still happening. The one suggestion I've read, not here, is use contact clean and a cue tip to clean the contact on the camera and batteries... hope that helps?
I have a Nikon S7000 and was also experiencing the 'Exhausted Battery' message- The Nikon manual for the camera- indicates an order to charging the battery and also for disconnecting the AC adapter from the electrical outlet-I also used a power adapter between the USB cable and the charging outlet. It now works!
is there AN opening to charge 900 camera? MAYBE YOU ARE TOO OLD AND FEEBLE TO EVEN HAVE THIS CAMERA !
yes I guess computer is right!
I've tried several times to put in new, fresh batteries - and within a few minutes "battery exhausted" message comes on, and I'm lucky if I was able to take even a couple of pictures! HELP!!
still no solution. Tried them all???
Exact same problem here - L21 eating away batteries in minutes, not hours. Any guesses?
/Per Hertz
It seems after you have bought enough batteries hoping two work, you may as well buy a new camera. I have the same problem and it is frustrating.
my camera had the same issue but it was solved by mata electronics in bangalore.pls contact them at mataelectronics@Gmail.com
How your problem was solved. Could you please advise ?
I bought a new phone - a Galaxy S21+5G - and never had a better phone!
If you have replaced battery and it still gives u that message, the battery terminals may be dirty or rusted, try the vinegar trick
What is the vinegar trick
Try pushing the battery in while charging.
I cleaned the terminals inside the lid of the battery compartment. Just scraped them with a screwdriver. It seems OK now, even on alkaline batteries with about 1.48 volts each.
Sometimes a pencil eraser works wonders...
Hi Cole, I had the same problem with my Nikon Coolpix L100. I tried everything, but without luck. I realised that in my case the problem was linked to Firmware being out of date. I wasn’t able to access the menu despite changing batteries.
I have purchased the power adaptor (the one that you put into mains), took out the batteries and powered up the camera. I declined to set up date/time and finally was able to access the camera. Hope this helps.
Hi! I also have a Nikon Coolpix L100 and have the battery exhausted issue. Could you tell me what type of usb cable you use? My camera was a gift and came without the usb so i want to know what to buy for it.
Don’t put your battery(s) in the camera until you are ready to use it. Especially rechargeables in DSLRs. Small internal workings will drain down the battery and over time, if not removed, the charge will be completely used up. If I’m shooting daily I leave them in but if a camera will be sitting for a few days or a week or, since I have a number of them, won’t be in use, the batteries come out.
My Kodak pixpro fz43 has the same issue Please help
Ayaan Pathan what issues does your camera have?
the issue is when im recording videos or using my camera the battery indicator shows that its almost dead and i used just for 17 min im dissapointed and dont know how to fix PLEASE HELP
I have the same camera and it used to last for ages. Tried it today and it ate 4 batteries in less than15 mins!!! WTF!
The battery case is not latching completely is the reason why the charge is not there.
SO how do i fix that???
I have Nikon B500 and in my case I got it solved with 2 steps:
--BATTERY MAY "HAD BEEN DROPPED" (IT FALLS DOWN EVEN JUST 20cm); INFORMATION FROM NIKON. (INSIDE THE REEL BATTERY HAS "SMALL CHIP REGISTERED INFORMATION, SO THE CAMERA CAN DETECT THE ORIGINAL BATTERY OR CLONE ").
-IF CAMERA CAN NOT DETECT IN CERTAIN TIMING IN (100MM-SECOND). IT WILL ALARM "ERROR" CODE.
--IF YOU PLACED YOUR CAMERA LENS "UP", MEAN THE CAMERA's BACK WAS DOWN (FOR A LONG PERIOD, SPECIALLY IN THE SUMMER). THE BUTTONS ARE TOUCHING THE BOTTOM OF THE BAG. SOME BUTTONS WILL BE "STICK" (CLUED)...
---THE MOTOR WHICH DRIVING THE "ZOOM" MODE IS NOT MOVE IN "REEL" TIME (AS IT PROGRAMMED, "IT CONSUMED A LOT OF ENERGIES"). THE ERROR WILL BE ACTIVATED.
----IN THESE CASES, EVEN YOU REPLACE THE NEW BATTERY. IT WON'T WORK.
A LOT OF DEVICES IN THE CAMERA WAS NOT COME FROM NIKON, MEAN FROM THE "THIRD PARTY" (NON-AUTHORIZED) CAN NOT UPDATE/UPGRADE.
NIKON INC. IS NOT RESPONSIBLE FOR (THESE "CLONED" CAMERAS). ALMOST
THE PRODUCTS "MADE IN CHINA" (CLONED PRODUCTS)....
Últimas 24 horas: 14
Últimos 7 dias: 73
Últimos 30 dias: 289
Ao todo: 114,127
21 comentários
@cjdspartan since we do not know what "everything online tells" you it will help if you let us know what you've tried.
por oldturkey03
Replace the battery :-)
por Kevin McCartney
I've replaced the batteries several times - even bought the best, most expensive ones and I still get the same message over and over - Battery Exhaused! Crazy. I love this camera's picture quality, but this is ever so frustrating! Sure do wish there was a "cure" for this problem.
por michellemplatt
Hello,
I am facing the same issue with my Camera Nikon L330.
I have charged battery many times and the charging light goes off withing few min.
After inserting battery it shows 100% and withing few min battery level drop to critical with message on screen "battery exhausted" and Camera turn off.
Could you please help me with this issue.
I have't purchased any sort of batteries yet.
por Nitin Kirnapure
I'm having the same problem too. And I'm using alkaline batteries JUST LIKE the camera is set for. And before anybody answers, consider this (and this is only directed at a couple of you)...
Do you @%^$$@$# seriously think we're stupid enough to try to use a camera with a dead battery? If we weren't using fresh batteries, we wouldn't be on this forum in the first place, we'd be out BUYING NEW BATTERIES. So if you've got something helpful to contribute, by all means, have at it. But if you're just here to troll, go &&^& a light socket!
por Eric Rahn
Exibir mais 16 comentários
