Ir para o conteúdo principal
Machine-readable instructions that direct computer processors.
210 Perguntas Visualizar todos
Pergunta encerrada
Launch command using app
MacBook Pro 13" Retina Display Late 2012
Could someone please tell me how to insert a terminal command into an "application" so when the app is clicked/opened the command is launched?
Thank you so much for your help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Have you reviewed Automator? You'll find it in your applications folder.
It allows you to create OS level scripts. If the given app is designed to support Automator then some functions internally maybe supported.
You'll need to talk with the application vendor if they support it and what the calls are.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 53
