Ir para o conteúdo principal
Xbox One antenna wire?
Anyone know if the antenna wire comes with rf board or wifi board via ifix shop? I have controller sync issues. I know it's from either a malfunctioning rf board or wifi board but wifi works like a champ so I'm leaning more towards the rf board. Lost the antenna wire connecting the to.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I recently had this issue
Try the basics
1. Replace Batteries
2. Cycle you're console
3. Reset wireless controller settings
4. Check for an update for you're controller
If any of these simple fixes do not solve / fix the issue try connecting it to another console if it works
Go to the final step
5. Replace Wi-Fi Board.
Order the tools and parts hear I promise you the $ is worth it
I tried eBay and was ripped off with a (tested and inspected used "working" board).
Ifixit Opening tool, Spudger, and the torx T9 tool (or at you're local hardware/ electronics store)
And the WI-FI Board aswell .
Use the guide's on easy tear down and repair.
I did it in two minutes because I had practice it's a simple easy fix
Hope this answers you're question.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ric Renfro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,042
