Ir para o conteúdo principal
A 2.5 gallon, 2HP utility Wet/Dry Vacuum manufactured by ArmorAll.
Why won't my vacuum turn on?
My vacuum is plugged into a working outlet but when I flip the power switch nothing happens.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Check vac switch
por
I did, it is not working but I don't know where to buy a replacement switch
por
Adicionar um comentário
2 respostas
Solução escolhida
There are a few possibilities as to why the vacuum won't turn on. First, check the cord for damage. Make sure to unplug the vacuum first. If the vacuum continues to not turn on properly, the power switch or the motor may be faulty. Refer to the troubleshooting page for detailed help.
Esta resposta foi útil?
Pontuação 3
Check vac switch. If vac switch the little yellow box on circut pop. Wnt switch on
Pontuação 0
Adicionar a sua resposta
Abel Manring será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 40
Ao todo: 9,031
