Ir para o conteúdo principal
The BLU Life 8 is a smartphone based on Android 4.2. It is equipped with a 5" display with 720 x 1280 pixels resolution.
Will not connect with pc
I was going to download music this way but the PC keeps saying "USB device not recognized". My phone is in the correct mode to transfer pictures and music between phone and PC but its not working. Can anyone help me out?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What kind of PC do you have? It might be the PC's problem, not your phone's. If you want to download music, you can go to http://www.youtube-mp3.org/
por
you need to check the usb connection or the cable. my phone like that too http://gadgetoh.blogspot.com/2016/06/4-s...
por
Adicionar um comentário
1 resposta
Solução escolhida
Have you tried a different cable and or different usb port . You may also want to check that your bluetooth is off as this has been known to cause issues. you may also want to try reinstalling the download drivers for the phone.
http://androidmtk.com/download-blu-usb-d...
Make sure you install the correct model drivers. Hope this helps
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Victoria Lingo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 209
