How can I switch the direction on the drill?
I need to unscrew a misplaced screw but I don't know how to switch it into a reverse position.
Esta é uma boa pergunta?
In order to change the direction of torque, fully toggle the switch above the trigger into the alternative position.
Esta resposta foi útil?
Hi does a black and decker bd163va have reverse.or what is the black round button for near trigger
I have a domestic 450w Black & Decker electric drill that does not have a reverse switch, yet it is turning anti-clockwise. Mind you, I lent this driller to someone who returned it long ago, but now I wished to use it in lieu of the other two that I have and discovered that it has started to turn anti-clocwise with the result that the chuck unwinds. Please can i repair it as it is adequate for me.
I do not know if he repaired it or not, because he passed away.
Re Black & Decker drill, it only has a common switch and a sideway button which when pressed while drill is functioning will render drill functioning automatically. Again, please anyone with a correct answer? Thanks beforehand.
Hi Mr Edgardo Gutierrez thank you for your answer. But my drill has a common switch.
It is possible to change the direction by reversing the brush connection which will be internal to the machine. Need electrical knowledge to do so.
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 54
Ao todo: 49,746
2 comentários
please tell me how the reverse mechanism works in bosch gsw 450re , because it isnt working in my machine ..
por nikhil nampalliwar
How to take a screw put w/ a 1/4in single speed drill by black &decker
por nehnemi130
