Ir para o conteúdo principal
A 4 Amp corded power drill released in June 2014 by Black and Decker. The corded device is a part of the Matrix Quick Connect System which enables various attachments.
My drill is slow. How do I fix this problem?
So in recent times, my drill has worked properly but this time I feel something is wrong with it because it is reacting very slowly compared to the other times I've used it.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
There are a few possible reasons for your drill to be slow, be sure to make sure you are fully compressing the trigger on the drill. If this is not the problem, another solution may be adjusting the clutch knob which has 11 positions.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I tried adjust the clutch knob but I am still getting the fast speed only..I am thinking it might be an internal problem
por
Adicionar a sua resposta
Tyler Yurina será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 37
Ao todo: 10,445
