96 jeep horn replacement
I have a new horn that is compatible with my model but it has different wires. no videos anywhere on the switch. help please!
Esta é uma boa pergunta?
If there are 2 wires coming off the horn and 1 wire into the horn then you need to ground the horn to the jeep body. If theres only 1 wire coming off the horn and 2 wires coming in then you need to create a ground by drilling a hole in the base of the horn and attaching the ground wire coming in there . Hope this helps
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 924
