Ir para o conteúdo principal
Tela de 15,6 polegadas. Identificado pelo código do modelo: NP470R5E-K02UB. Este dispositivo foi lançado em agosto de 2013.
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
Esta resposta foi útil?
Pontuação 1
1 comentário:
hi brianstrech,
how did you guys glue the keyboard back?
por
Adicionar a sua resposta
Max Rysdon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 30
Ao todo: 1,973
