Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Perguntas Visualizar todos
Nintendo DS Lite Will not turn on
So about a month after I got a Nintendo DS Lite motherboard and installed it, It would not turn on or charge. When I plug it in, the charge light turns on for about a second and then turns off, and when I push the power switch up, Nothing happens whatsoever. Both fuses are good(0 ohms), and L2 reads fine, there is continuity between the power switch and pin 12 (PWSW) of the power management IC. I have another DS Lite motherboard that will charge but will not turn on (both fuses good), and the game card slot is taken off. So I have a parts motherboard if I need it. Help will be greatly appreciated because I really need to do my daily Brain Age.
Esta é uma boa pergunta?
Pontuação 5
3 comentários:
Do you have a spare battery that you can test the DS Lite with?
por
Yes I do, still does not work. It is supposed to turn on even with no battery when plugged into charger. (and yes the charger is good.)
por
I am sorry, I have the same problem with mine, too. If I find out how to fix it, you will be the first person I tell.
por
Adicionar um comentário
1 resposta
If you're absolutely positive you're F1 & F2 fuses are good, double check the soldering job on the charge port. There may be only 1 pin connected or it's lifted somehow. Beyond that, keep testing with a known good working battery. Generally, I've found, that if there is no green power light coming on, it's either the battery, charge port, F1 or F2 fuse.
Esta resposta foi útil?
Pontuação 0
1 comentário:
What if my orange charge light comes on when I plug it in but as soon as u try to turn it on the green powered on light stays on for 1 second and the bottom screen stays blackwhile the to screen flashes from solid black to white just once the powers off and still is indicating that its still charging
por
Adicionar a sua resposta
Nathaniel Clark será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 2,246
