Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Perguntas Visualizar todos
MacBook Pro wont charge or run on battery
Hello!
After changing the battery of an MacBook Pro 13" retina late 2012 the device will not run on battery power, or charge.
I can supply picture of the motherboard if needed, to see if i may have broken an component.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
sounds likes a faulty battery. not much alternative a part for buying a new battery.
Esta resposta foi útil?
Pontuação 1
1 comentário:
The battery showed as invalid. Thanks for help! After replacing the battery twice i got one that worked.
por
Pergunta mais útil
Download and run Coconut Battery to see the condition of the battery and if it's even being seen. Did you use the guide? What was the source of your replacement?
http://www.coconut-flavour.com/coconutba...
Pontuação 3
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 164
