Ir para o conteúdo principal
Um tablet Zeki de 8 polegadas com tela tátil e processador dual core, equipado com câmeras duplas. O número do modelo deste dispositivo é TBQG884B.
Device won't boot past "Android logo" splash screen
Presently, device will boot past the "Zeki" screen but will hang on the "Android" screen. We've let it sit for more than 60 minutes.
Attempted to do a factory reset.
Physical and online manuals do not address how to do this. Listed technical support has been unhelpful. Attempted at least twelve separate, recommended ways of doing a factory reset using the physical buttons (Pressing multiple combinations of the power button, vol + / vol - / both, and the reset button for varying lengths of time at different times during the reboot process). However, I'm certain I haven't tried every combination of buttons, press durations, and timings.
As a last-ditch effort I'm letting the battery run out in an attempt to make it forget everything, but I don't if that will accomplish anything (or how long that will take--days? weeks?).
Any advice on how to achieve a factory reset for this device, or otherwise restore functionality?
Esta é uma boa pergunta?
Pontuação 8
Adicionar um comentário
2 respostas
Try holding down the power button and the volume down button for five seconds and then releasing them. This should bring you to the fastboot menu where you can perform a factory reset, I would try this again.
Esta resposta foi útil?
Pontuação 0
2 comentários:
eso ya lo hice y nada. que hago entonces?
por
Es posible que haya alguna manera corrompido los archivos de Android, si ese es el caso, no hay nada que pueda hacer por ti. (Estoy usando Google Translate, lo siento por la redacción raro.)
por
test combo: vol_+ & pwr_btn
Pontuação 0
Adicionar a sua resposta
Chris Rutledge será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 2,833
