Ir para o conteúdo principal
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 Perguntas Visualizar todos
Inserting Home button cable in socket
All the guides just assume that once you get the device apart that you can reverse the instructions and get it back together again. On the Ipad 4, I have found getting the home button cable back into it's connector to be anything but easy. In my case, I can only get the cable around halfway into the connector before it starts to bend/tear. I do have a spare as the home button assembly was not damaged on the old digitizer but I don't want to swap over to it until I have better grasp on how to get it plugged in without damage? Any ideas on how to get the cable fully into the connector?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It is definitely a pain in the ass.
if you're installing a digitizer with the home button flex already installed, it is much easier to take it off, plug it in to the connector, and then attach it to the digitizer. :-)
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
crusher171 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 167
