Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
Why is my PS3 so loud?
Noise ramps up to max fan speed within 5-10 minutes. Regardless of external temperature.
Had the PS3 opened by a professional, dust cleaned, new thermal paste, same problem.
Suggestions on how to fix? Problem with heat pipes on heat sink?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have a similar problem, the fan starts off quiet then after about 20seconds starts to speed up this is just on the menu page not in any games or anything. after about 1-2 mins the fan is at full blast.
I've reapplied the thermal paste on the main processors, no effect, how reliable are the heat-pipes on these? I've had them go on CPU HSF's before. If I leave it on it stays at full speed and if I turn it off and on straight away it'll start mid speed and then reach full speed before its even finished booting. likewise if its cold it'll last longer before it speeds up.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
1. Your PS3 may have a faulty temperature sensor making it unable to detect the heat of your PS3 and it's default is to set fan speeds to max incase of overheating.
2. Your PS3 may have a faulty fan due to previous dust or heat. A replacement may work.
3. If it's an older PS3 the CPU heats up more for newer games, the newer games use more CPU power causing it to heat up faster and the fan to speed up to prevent overheating.
Esta resposta foi útil?
Pontuação 2
I had this problem after I repaired the PS3 because the YLoD. I opened up the 3 again and noticed that the thermal paste was not making complete contact with the heatsinks even though they were screwed down tightly.
I decided to apply another layer of paste to both heatsinks and this seems to have quieted the fan down. You could try that
Pontuação 0
Adicionar a sua resposta
caseten será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 6,634
