Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
20 Perguntas Visualizar todos
Wifi button greyed out
I replaced the screen and after awhile the wifi button cannot be activated, should I replace the motherboard?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
No, you will probably just have to replace the wifi antennas, which is probably what got ripped when you opened the device.
Esta resposta foi útil?
Pontuação 2
3 comentários:
I agree, everyone who has worked on iPads enjoyed one day or another a teared up wifi antenna ;)
por
Yup. Happens when you put the pick too far in on the right side.
por
What I'm afraid of is the wireless controller being messed up. That would be a board-level repair.
por
Sounds like you didnt reseat the wifi module properly, or as you were dismantling it you cracked part of the ribbon cable.Check , reseat, or replace the wifi module.
I assume you tried doing the cold reset and switching in amd out of airplane mode, this is usually a fix for airplay too when that “greys” out.Hope this helps.
Pontuação 1
Replace your wifi antenna iPad 3 Wi-Fi Wi-Fi Antenna Replacement
Pontuação 1
Adicionar a sua resposta
Eric Wayne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 241
