Ir para o conteúdo principal
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
316 Perguntas Visualizar todos
Top screen has patchy red discoloration that moves?
The top screen on my DS Lite has developed an issue where usually the top part of the screen (or sometimes all of the screen) will develop a red tinge and turn all the colors on the screen more red. I don't think the screen is necessarily damaged because if I tilt the screen forwards or backwards it can either get better or worse (more of the screen turns red or less, sometimes even none if I tilt it just right). Is it some kind of connection in the hinge or something along those lines?
Thanks.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
That tends to happen if the backlight is beginning to fail. Moving it may help some but eventually it will fail completely.
Esta resposta foi útil?
Pontuação 2
1 comentário:
That usually happens when's the screen is stepped on.
por
Adicionar a sua resposta
Taylor Whitney será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 469
