Ir para o conteúdo principal
Pergunta encerrada
Can I upgrade my memory to something more than 6 GB?
Hi everyone, I have a Toshiba Satellite L755 PSK2YE-0KW00YFR as you can clearly see in the description and i have 6 GB of memory, 4 GB in one slot and 2 GB in the other, my question is, can i expand my memory to more than that ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The Satellite L755-S5173 has 4 GB of memory (RAM), which is the minimum required to handle the workload of the average user using modern applications. If you find it slowing down when multiple windows are open, consider buying more RAM, as the memory is expandable up to 8 GB. There may also be other models of this laptop that come with the full 8 GB.
http://laptops.specout.com/l/724/Satelli...
Esta resposta foi útil?
Pontuação 4
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 144
