Ir para o conteúdo principal
Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
573 Perguntas Visualizar todos
Pergunta encerrada
Anyone knows where I can buy the plastic bezel?
Hi,
I'm searching for a replacement plastic bezel/frame that's behind the lcd/digitizer of a Microsoft Surface Pro 1514 (where you put the glue/double sided tape on).
When I opened my tablet I applied too much heat to weaken the glue. The bezel was damaged in the process and I'm unable to find a replacement.
See the attached photo for the damaged bezel and for the complete picture of the bezel (in his hands).
Original part info: Enclosure, Main, Top, Injection Molded ABS Polycarbonate, w/ PSA, X870178, CAV 4, >PC+ABS<
Hope you can help me out
Or to give me tips on who sells this replacement part
Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
From doing a search on eBay, I found one listing that met your model and specifications.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 815
