Ir para o conteúdo principal
Released July 2014. Model number NS-15AT07. Seven inch capacitive touch Android tablet with external camera.
Why does my insignia flex 7 NOT charging?
i inserted my charger into the port, but it won't charge my tablet. I may have inserted the charger the wrong way, so it damaged the port. How do I replace it.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
sometimes if you do not use the original charger and cord then the device will not get enough amperage to charge. i have had this happen with many tablets. also sometimes it can be the charger part is messed up or lose and finally the battery could just be messed up. try a differ charger to see if that works and if you can try to replace the battery and see if that makes a difference. i hope this helps and good luck on your issue
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mely1127 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 1,233
