Ir para o conteúdo principal
The Sony Xperia Z3 is an android smartphone released in 2014 known for it’s long battery life and durability.
20 Perguntas Visualizar todos
Can I reuse undamaged back cover?
So essentially I got a Z3 for pretty cheap (200 Euro) however the camera lens is full of dirt which makes the photos come out kind of bad. I was wondering if I could remove the back cover, clean the lens and use new back cover adhesive but keep the same glass cover?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Absolutely! Just be careful not to damage when removing. It is adhered to the back of the phone and cracks easily. I would use plenty of heat and have plenty of patience when removing the back. I would also check ifixit for a guide, or youtube!
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks I'm going to go order the adhesive tonight.
por
I would recommend replacing the entire back glass after removing it.
They are dirt cheap to buy and saves cleaning it/adding new adhesive.
You can probably buy the back glass with adhesive not much more then the actual adhesive.
Pontuação 0
Adicionar a sua resposta
Hup será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 440
