Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Pergunta encerrada
Replaced a Cracked Display, Colors are Off
Hey all,
I purchased a replacement display for an iPhone 5s from ifixit and I did the replacement. Everything went great and when I turned it on it worked mostly but for some reason the colors are off. Everything seems really really dim compared to my wife's normal iPhone 5s. I redid all the connections but nothing is changing in regards to the colors. There are also light spots at the bottom of the screen. Also these pictures are taken with both phones at max brightness.
Any suggestions? Pictures below to see what I am talking about.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like a damaged display assembly. I can't say if you just got a bad one, or if you damaged it during the repair. You can try to send it back as a warranty, with ifixit, to see if they'll send your new one
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 57
