Power Book G4 Keeps freezing
Hi,
I have a power book that I recently replaced the DC board on and now it keeps freezing up, before it would only do it after being on for a little bit now it wont go past the startup. I'm not sure what it could be.
Esta é uma boa pergunta?
4 comentários
Sorry for the late response. I bought the system installation disk and ran hardware tests and disk utility to check the hard drive and repair it. Everything passed. I took it apart checked everything and then put it back together. Then ran the tests again everything passed and the computer worked for like 3 hours then the same thing started happening again. I know the battery is bad and when I take it out to run only off the outlet it won’t turn on. I'm starting to think the DC board I bought is faulty. Also the power adapter is an after market one that says it works for apple. I didn't buy it, but the person who gave me the computer did saying that the DC board was bad. I don't want to put more money into it because it's not worth it. I just want to know what is wrong with it I've worked on computers and laptops for 2 years and never had this much of a problem as I've had with this one.
por Dennis
Thank you will try tomorrow and let you know.
por Dennis
I checked everything in the fan setup there and cleaned it. I also, noticed the copper rod underneath has broken loose I am going to borrow a friends solder gun and try to resolder it.
por Dennis
Well I fixed the rod, but now the computer is not working. I hear everything start up, but no chime and the screen doesn't turn on, it stays off. I took it apart twice to check everything and everything seems connected. I'm thinking about breaking it apart and selling the parts that I know are good.
por Dennis
