Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20011 Perguntas Visualizar todos
Fan spins but the screen is black and won't boot.
We've tried some quick google'd resets as well as many of the fixes found in this forum to no avail. Proper 85w charger installed.
Update (01/24/2016)
Ah yes, sorry about that, I guess I assumed that it had posted the model and all that since it asked me all those questions just to get to the page to post the question.
It's an 07 macbook pro prior to the unibody. Basically what happened is that I took it to apple to replace the battery, tech walks away with laptop replaces battery comes back and it now won't reboot. I've tried the resets found when searching here on the forum. It will power up but all you can here is the fan spinning. it doesn't sound like anything else is running at all, nor will the screen light up. No start up ding or noise.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
@eholm522 you do want to start by identifying which MBPro you have. There are quite a few variances. Then you want to tell us exactly which fixes from this forum you've tried. Details are important if you want to get helpful answers.
por
I understand your frustration with the Apple Tech. You paid for a new battery and got a dead machine. You did not attempt a power on at the store. WE are here to help you without charge. Help us to do that. Why did you replace the battery? Help us to help you by giving us all the information related to repairing your machine that you can. There are known issues. We do this every day. You won't find better Mac Techs in the world than right here. You are at the top.
por
is it a 15" or 17" inch model? What's your computers serial number? something like a A1150 A1211 A1226 or A1260?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Eric Holm, start off with the "no Power " trouble shooting procedure.
The computer will not power on (no sleep light, no fan movement, no hard drive spin-up, no Caps Lock LED illumination when pressed, and no display illumination).
Note: After each step, check that the system is not supplying power to the logic board. If you see the sleep LED come on or the Caps Lock LED illuminate when the key is pressed, then the system is indeed drawing power. In this case, hold down the power button for six seconds to insure the system is shut down before working on the machine. At this point, the issue is no longer a ‘No Power, No Video’ problem. Move on to the Power, but No Video troubleshooting section.
Note: Examine the display carefully. An image may be barely present on the screen, but with no backlight clearly illuminating the image. In this case, the system is working properly except for the backlight. Use the ‘Display: Dim Video’ troubleshooting section to resolve this issue.
1. Remove any connected peripherals and eject any ExpressCard.
2. Check that the battery has enough charge to start the computer by pressing the button next to the LEDs on the battery (on the bottom of the machine). At least one LED must light solid (not flashing). Make sure the battery is fully seated.
3. Connect a known-good Apple 85W Portable Power Adapter and power cord or plug to a knowngood power outlet. If the DC plug is properly inserted, the LED should light up; if not, go to the MagSafe connector troubleshooting section.
4. Try powering up without the battery installed. If it boots, try a known-good battery. If it does not boot, replace the battery connector cable.
Note: With the MacBook Pro (15-inch 2.4/2.2GHz), unlike previous models, if you use the MacBook Apple 60W Portable Power Adapter to power the system, the battery will need a minimum charge to be able to boot the system. If the battery is fully depleted and no 85W adapter is available, allow the battery to charge first before turning on the system.
5. Reset the SMC (power manager). See the procedure under the Resetting the Power Manager (SMC) heading in the Hardware Troubleshooting Tools and Tips section.
6. Try to power up the system and check the sleep indicator. If it turns on solid and turns off, the main logic board is getting power and completing the boot cycle. Go to the Power, but No Video troubleshooting section.
7. Verify that the power button cable is connected properly to the top case flex cable assembly and that the flex cable is connected correctly to the logic board. Try turning on the system.
8. Disconnect the keyboard completely. Inspect the connectors. With the keyboard disconnected, restart the system using the on-board startup jumper pads. If it boots, replace top case.
9. Remove any additional RAM.
10. Try removing the AirPort Extreme card from its socket and start the computer. If it starts, shut it down and check the flex cable connector and the connector on the logic board and replace the damaged parts.
11. Reseat these flex cables:
• Left I/O flex cable
• Hard drive flex cable (will boot to flashing folder if not connected or corrupt)
• Optical drive flex cable
• Trackpad flex cable
• Display LVDS cable
• Thermal sensor cables
12. If the computer starts up, inspect any suspect flex cable connectors and their terminals on the logic board for damage and replace any damaged parts.
13. Replace the left I/O board.)
14. Replace the logic board.
Power, but No Video (Computer begins to power up, the fans and hard drive spin, the Caps Lock key lights up when pressed, but there is no startup chime or video.)
Note: Examine the display carefully. An image may be barely present on the screen, but with no backlight clearly illuminating the image. In this case, the system is working properly except for the backlight. Use the Display: Dim Video troubleshooting section to resolve this issue.
1. Reset the power manager. See procedure under Resetting the Power Manager (SMC) in the Hardware Troubleshooting Tools and Tips section.
2. Try connecting an external display to check for intact video signal. If external video appears, check the system for any pending software or firmware updates and update accordingly.
3. Verify that the LVDS cable connection is properly seated to its connector on the logic board and that the cables are not damaged.
4. Remove the display housing and check that the flex connection is properly inserted, aligned and seated in its connector on the panel. Misalignment can cause multiple video issues. During insertion, the connector should be perfectly straight, not at an angle, and the connector should slide into its mate in a flat position, parallel to the LCD panel, not obliquely.
5. Replace the display assembly.
6. Check all cable and flex connections to the logic board. Try restarting.
7. Replace the logic board.
These are just a few things you should try to begin trouble shooting. Again let us know exactly what model your MBP is. It is best identified by the complete serial number.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Eric Holm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 33
Duração total: 3,247
