Ir para o conteúdo principal
Wi-Fi is grayed and No Bluetooth
My phone6 wifi connection is greyed out and blue tooth is not working, I have tried all the method post to web, the problem still not Fixed. look like have need replacement of the iPhone 6 Wi-Fi Antenna replacement.
Can someone tell me is
iPhone 6 Top Left Antenna
had fix the problem using above wifi replacement or any issue.
Imagem de iPhone 6 Top Left Antenna
Produto
$9.99
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The wifi antennae is the first thing I would look into, after that it's like what jump1n said, you'll have to have the board worked on
There isn't a guide for it, now. You're not supposed to use the teardowns as guides. But I do it all the time
iPhone 6 Teardown
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
I had the same problem and with the iPhone 6 this is a very unknown issue and I researched into it and found this. Something may of come loose connector wise check thembut in setting under wifi address it says NA then yes try those but I reckon it's the wifi chip has benn moved from its place on the motherboard, replace that and it'll be good as new,
Hope I helped
Regards
Lucas
Pontuação 0
Adicionar a sua resposta
hklha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 555
