Ir para o conteúdo principal
Modelo A1418 / Final de 2012 / Processador Core i5 de 2,7 e 2,9 GHz ou Core i7 de 3,1 GHz
No Power - won't turn on
My computer just shut down and won't power back on. Won't do anything. It is like it isn't even plugged in. I have tried a different power cord. I tried holding the power button. I have unplugged everything from the usb ports.
I have opened up the computer - I am wondering where the diagnostic led lights are. I am wondering if it is the power supply board - it does look like some wiring melted - although its not black or burnt...
Imagem
Esta é uma boa pergunta?
Pontuação 2
2 comentários
The diagnostic LEDs are to the right of the RAM slots.
por
Could be a bad power supply unit
por
Adicionar um comentário
3 respostas
Solução escolhida
Be sure to discharge the big capacitors and handle it with one hand. I may be mistaken, but that looks like where the transformer bridges from the AC side to DC side. It will have very high voltage there. If that's exposed wire in the pic then it is likely indicating a problem. The end of one wire looks yellowish too, as if it may have been hot. All of your symptoms point to a bad power supply. About 70% of the time I see these it's the Power Supply, so I'd definitely put my money there.
Esta resposta foi útil?
Pontuação 2
The diagnostic lights are to the right of the RAM slots.
Pontuação 2
The diagnostic lights are under the RAM slots. See picture
Imagem
Pontuação 1
Adicionar a sua resposta
Lesli KeepSimple será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Ao todo: 1,841
