Location of Bluetooth Antenna Board within the 2008 3.1 Mac Pro Case.
== Where is the Bluetooth ''Antenna Board" located inside an April 2008 V3.1 MacPro Case.
Please ??
This is Not the BT Module. mounted on the Logic Board.
But is connected to it by the Fine Coax Cable marked "BT"
How do I get to it.?? as I have a unit with the Mini Connector striped of the BT Antenna Cable which is unrepairable.
Is it necessary to mount a replacement board in the same position ..??
The New Ant Board has a One (1) Screw , apparently Earthed Mounting. on an 8.5cm x 1.5cm. panel.
Esta é uma boa pergunta?
