Ir para o conteúdo principal
How can I troubleshoot keys not working
I changed the display assembly following the great guide.
Unfortunately I must have messed up something. The shift keys and a few function keys are not working anymore.
I connected a bluetooth keyboard and it works all fine with that one. I assume that it is some hardware issue.
Is there something I can test before changing the keyboard
Maybe some cables that are not connected
Any idea is very welcome
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Can you give us your systems serial number so we can correctly identify which model you have.
por
Dan. The model number is A1370. The Serial number is C02G59XCDJYD.
por
Adicionar um comentário
2 respostas
try disconnect keyboard strip and try reconnect it back ...if it is a carbon strip clean it with soft dry stuff
Esta resposta foi útil?
Pontuação 0
1 comentário:
I"ll give that one a go once I'm back home. Thanks for the suggestion.
por
My preferred way is to load into OSX Apple>System Preferences> Keyboard, check the box "Show Keyboard & Character viewers in menu bar" Click on the new icon and choose Show Keyboard viewer. It'll give you a digital display of the keyboard that will react to each key that you press.
Pontuação 0
1 comentário:
I did that one and the keys do not react on the keyboard viewer. They react on Bluetooth keyboard but not on the keyboard
por
Adicionar a sua resposta
Edward Omagbemi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 960
