Ir para o conteúdo principal
O iPhone 5C da Apple foi lançado em 10 de Setembro de 2013. O reparo deste smartphone é similar aos modelos anteriores. Você precisará de chaves de Fenda/Philips/Torx 0.8 e espátulas de plástico. Disponível nas versões GSM ou CDMA / 8, 16, 32 GB / Branco, Rosa, Amarelo, Azul e Verde.
1233 Perguntas Visualizar todos
Pergunta encerrada
No camera holder on replacement screen
I've bought a replacement screen which was advertised to have the camera holder but it in fact did not.
I was wondering if it was possible to transfer the plastic camera holder from the old screen over to the replacement screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Yes, it is. Sometimes I just place the camera holder in there, and then place the camera/front flex assembly. Without making sure it's adhered. Just make sure to note position of the plastic bracket, and you should be fine
Esta resposta foi útil?
Pontuação 2
2 comentários:
How can I get the holder off of the old screen? And I just just have it loose in the new replacement screen? Will it stay there?
por
You can pry it off, somewhat gently, with tweezers, or even a flathead screw driver. Yeah, while laying your new display assembly down on your table or work area, it'll stay in place, while you put your front display and speaker on
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 54
