Ir para o conteúdo principal
ZTE Boost MAX N9520 boasts a 5.7-inch HD IPS Display with 4G LTE and Android 4.1.
59 Perguntas Visualizar todos
Phone storage problem ,always get the running out of space icon
My boost max zte is always saying low storage and even if I uninstalled 1/2 the apps it still says insufficient storage to update or download some apps . I have tried to transfer files and apps to my sd card but still get the insufficient storage problem
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
I've been having this problem for about a month I downloaded everything to my memory card and still tells me phone is running out of space or I can't even send a text without deleting everything and I still can send a regular text and it keeps on telling me insufficient meant you no space what I got to do without deleting you know pictures o music 16 GB hard drive you know my internet says everything is just you know running out of room
por
Adicionar um comentário
1 resposta
Basic possible fix to see if this helps as when you say you have deleted everything accept the cache as well and that is most often the problem.
To clear the cache open settings then Storage and tap on cached data and in the next screen choose to delete. This is just junk files and no personal data is deleted doing this.
I would also delete cache partition from in recovery this often fixes bugs in the Android system such as telling you the storage is full it also often improves performance so worth doing and again no personal data is deleted doing this
To wipe the cache partition we need to boot into recovery
With the phone turned off hold the home key and the volume up key then turn the phone on keeping those two pressed. This is the most common method used by manufacturers to boot into recovery but without knowing what phone you have I can not tell you if this is the right way for your device. If that is not working for you use this link to find the method for your phone all phones running Android will have a method to boot to recovery.
When you have booted into recovery use the volume keys to move down the menu to Delete Cache Partition and press the power key to select it and follow the prompts it only takes a few seconds then reboot the phone the reboot can take a little longer than normal. I hope this helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Duração total: 1,335
