Ir para o conteúdo principal
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
How do I stick volume buttons to the bracket
I tore the power/volume cable while replacing the screen. I purchased the new cable and finished disassembly. While trying to reassemble, I peeled the protective covering off of the cable beneath the volume and lock components. When I press them to the bracket, the buttons and switch (the last step/first step in reassembly) will not stick. They pop off when trying to stick the next one on. Is there another adhesive I can apply to get them to stick that will not damage the cable?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
When using super glue, , I use a needle to stick down the tube of superglue and that way you only transfer a tiny amount of glue from the end of needle onto your cables and it keeps from getting too much glue from spreading to other parts of the cable.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes, that a common problem. You can use quality double sided tape, you could use a very small drop of supper glue if it's the only alternative. But only a small amount that only covers the back, without it getting on the front or sides of the cable. Do one at a time and let dry before installing.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I would recommend using super glue as a last resort. Its a pain to deal with if you ever have to work on it again.
A little double sided tape works fine as long as you don't use too much.
por
Adicionar a sua resposta
Matthew Kovnot será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 188
