Ir para o conteúdo principal
The TI-84 Plus Silver Edition is a graphing calculator released in 2004. It includes a USB port, pre-loaded software, APPS, storage, and a removable front and back case.
32 Perguntas Visualizar todos
Why are the batteries not lasting more than a couple days?
All of a sudden, my calculator stopped working for more than a couple of days after I put in new batteries; even when I only use the calculator for a couple minutes on one or two days! I tried replacing the backup battery, but this doesn't seem to have done anything. I'm not sure if there's a short in the power system or what the problem is. At one point, I had left some old batteries in there for a long time, and one of them looked like it was starting to leak some chemicals out. I wiped them off and cleaned out the battery compartment as best I could, but since then the new batteries just haven't worked for very long. What could be causing this, and what can I do about it? I'd rather have it fixed for cheap, or fix it myself if possible with my skill range and tools, than purchase a new one right now.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Like you feared, this is probably a hardware failure. You can try to replace the motherboard using this guide however it’ll probably be much easier just to buy a new calculator or remove a battery when you’re not using it.
Sorry about this, corrupted batteries always screw up something. :\
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ari Hodes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 130
