charging port is malfunctioning
re: 7th gen. ipod nano. does not always charge. requires a rubber band contraption to keep lightning cable connected charging ipod. I'm assuming the port needs cleaning/repair/replacement?
Esta é uma boa pergunta?
You should start by trying a new charge cord . if that brings no joy then you may need to replace the charging port. this teardown guide can help you through the process .
iPod Nano 7th Generation Teardown
Hope this helps
Esta resposta foi útil?
were can i get my ipod nano fixed
Is the charging port soldered or plugged in? Thank you,
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 7,720
