Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
Why is this device ghost touching after replacing the screen?
I replaced this iPad Mini 3 with a new screen from iFixit and the customer brought it back saying that it was doing things on it's own without her even touching it. I confirmed that is the case and it seems to be happening when a slight bit of pressure is applied to the lower left or right corners. I took a video if you would like to see it happen. I opened it up again and nothing looks pinched and I put some EMI tape over the home button cable, since I read that may help. ANy ideas here? I also ordered a new screen in case I have to go that route.
Thanks in advance!
Bodhi
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Have you confirmed that the cable for the digitizer is seated correctly?
Also, I have heard that a power cycle may also fix the problem sometimes.
Esta resposta foi útil?
Pontuação 0
I have the same problem with an iPad 3 4G... Even when the digitizer isn't touching the frame the iPad goes crazy. I've tried different digitizers from different companies but still having problems. I know the solutions for the iPad mini 1 and iPad air but with this one i'm stuck... Anyone?
Pontuação 0
I too just posted this similar question on fixit and i'm in the same boat and no one seems to have a fix for this. We order our parts from china and are the same that many companies sell here in the states. I have contacted my supplier about this issue he stated I should try OEM original apple screen for the iPad mini 3. So on my next order I'll be ordering some. I'll report my outcome.
Pontuação 0
1 comentário:
I think it's just bad quality batches of digitizer glass touch screen. I've been repairing many iPad Mini 3's without issue using Kapton tape as a safe measure.
por
Adicionar a sua resposta
Mac Daddy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 490
