Ir para o conteúdo principal
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Will not load operating system...
Our Mac Pro 5 powers up, but will not load the operating system. It gets stuck on the grey screen with Apple logo, and appears to be loading. After a few minutes it powers off, and re0boots, continuing this pattern until i manually hold the power button down to power off. Please help!
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Your hard drive may be fouled up, or your OS is severely corrupted. Try booting into safe mode by holding the Shift key as soon as you boot up. If you are able to Boot properly in safe mode, check your Hard Drive using disk utility and make repairs if necessary and immediately reboot. This failing, get back to us.
Esta resposta foi útil?
Pontuação 3
2 comentários:
+ If it will boot from the System DVD, then Majesty is correct.
por
agreed with mayer's caveat +
por
install another harddisk and put a fresh osx install on it. Then migrate your data.
that if it's the harddisk.
Pontuação 0
Adicionar a sua resposta
Erin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 3,136
