Ir para o conteúdo principal
The Nissan Xterra is an SUV that was manufactured and marketed by Nissan Motors across two generations, utilizing its Nissan F-Alpha platform shared with the Nissan Frontier pickup.
20 Perguntas Visualizar todos
What if my clutch pedal switch is bad
2001 Nissan Xterra. what if the clutch pedal switch is bad
Esta é uma boa pergunta?
Pontuação -1
1 comentário:
Ashley Woody clutch pedal switch? Not sure what you are referring to. What does or does your clutch not do? Give us a better idea of what your question is about.
por
Adicionar um comentário
1 resposta
Usually the only function of a clutch pedal switch is to make sure you have a foot on the clutch when starting the engine.
There are potentially 2 failure modes:
1 you can't engage the starter even if you do step on the clutch pedal
2 you no longer have to step on the clutch to engage the starter
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ashley Woody será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 254
