Ir para o conteúdo principal
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
Squeaky noise while running
I'm trying to find a pulley repair kit to fix the pulleys and or belt on my dryer but am having trouble finding the parts. My dryers model number is MEDB400VQ1 and serial number is M13013565.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
My washer maytag Brovos quiet series 300
Mvwb450wq1
Ser# co3170851
While it's running it sounds squeaky noise
An right after it spin it shows a UL an on the screen and it stop with out done ????
por
Adicionar um comentário
1 resposta
Solução escolhida
Drive Belt
The drive belt is a very long, slender belt that wraps all the way around the dryer drum, around a tension pulley, and then around the drive motor. Over time, the drive belt can become frayed or otherwise damaged. If the drive belt is frayed or damaged, the dryer will be noisy as it turns. Inspect the drive belt for signs of wear. If the drive belt is worn, replace it.
Drive Belt - Mfg Part # W10136934
Cause 3
Drum Roller
One or more of the drum rollers might be worn out. Many dryers have two drum support rollers on the rear of the drum, and some dryers have two more rollers supporting the front of the drum. When the drum rollers are worn out, they can cause the dryer to make a loud rumbling noise. To determine if the rollers are worn out, inspect the rollers. If one or more of the rollers are severely worn, we recommend replacing all of the rollers at the same time as a preventative measure. (The roller shaft can often be reused if it is in good condition. Clean the shaft thoroughly before installing the new rollers.)
Parts
Drum Roller for your Dryer
Drum Roller - Mfg Part # W10314173
Imagem de Connects the motor to the drum in your dryer to enable drum rotation.
Produto
Whirlpool Dryer Drum Belt - WPW10136934
$47.99
Imagem de Supports the dryer drum, helping it rotate smoothly while preventing noise during operation.
Produto
WPW10314173 - Whirlpool Dryer Drum Support Roller
$16.99
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Jody será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 4,802
