Ir para o conteúdo principal
The Acer Aspire One model D225E is a 10.1-inch netbook that features an ultra-thin and lightweight design with a powerful battery making it ideal for everyday computing on the go. Also known as Acer Aspire One D255E-13639.
20 Perguntas Visualizar todos
plastic top case cover hinge is broke
One of the plastic top case cover hinge is broke. It was dropped and the hinge (which is part of the plastic case top) broke into pieces. The computer stills works fine as does the screen. I want to replace the top plastic cover and use my current screen.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Upon doing a search on eBay using the terms "Acer Aspire One D255E" "cover", three parts came up. I believe the first is what you needed.
Acer also has a list of partners that you may want to contact. I also found CDS Parts.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Marc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 543
