Ir para o conteúdo principal
Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
Kernel panics immediately upon powering on and shuts off
Hi! I acquired a large quantity of 12" iBook G3/500s, and while a good quantity of them work fine, many of them (about 30) kernel panic immediately upon powering on and shut off. They do sometimes boot up fine and work for as long as you keep them on, but then they tend to shut off again when they are rebooted. They usually start working again when you make a change (i.e. add RAM, reset PRAM), but just when I think I've fixed one of these machines, it starts shutting off again. My first suspicion was that it was a memory issue, however they are just as likely to do it when all expansion RAM has been removed. I've tried resetting PRAM/PMU, loading an image vs loading the OS manually, and all the usual stuff. The interesting thing here is that there are so many similar machines acting in a similar way...it makes me think the cause of the problem must have been environmental, or that they all came from the same (bad) batch? Anyway, if you have any thoughts I'd be very interested to hear.
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Always such interesting questions +
por
I agree rj
por
Adicionar um comentário
1 resposta
Solução escolhida
Since you have so many, I'd take the logic board only out of ones that's not working and put it in one that is working. That would cut your time running diagnostics by days.
Esta resposta foi útil?
Pontuação 2
2 comentários:
A good start +
por
Interesting idea...what would it prove, though? iBook logic boards are not really removable like they are in a 13" Pro. Would transplanting a logic board really tell you anything that removing/replacing the shielding/RAM/Airport/DC-in wouldn't tell you? It seems that it would likely just move the problem to the other machine (if an iBook without a logic board could even really be referred to as a machine).
por
Adicionar a sua resposta
rdklinc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 19
Ao todo: 1,732
