Caliberates only to the right
The original problem was that the pc wasn't seeing the wheel. Well I moved a sensor closer and fixed that but then with the ffb coming back it kicked it all the way to the right no matter what I did. I tired calibrating it through windows. That didn't work so went back in and looked around to see if I could do anything else.I messed with the sensor again and nothing. I even flipped the wheel over just to see if I could trick or what others have said it wont calibrate which isn't true.It will. Something tells me it deals with the FFB and maybe a motor but I do not know.Please help. Thank you.
Esta é uma boa pergunta?
